Using a User Parameter in Esri Geodatabase (SDE) Writer Where Clause causing missing quote error
  • Dec 22, 2023 1:59 PM UTC
  • 80 views
garbadek
I have what I hope is a simple question. I'm using a Where clause in my Esri Geodatabase (SDE) Writer. One of the criteria I'm using in my Where clause is that a jurisdiction matches a value being passed in using a User Parameter. This value "jurisdiction" parameter has a comma in it (which I think is the problem). When I manually type the Where Clause in as Jurisdiction = 'SomeName County,St' it works no problem. When I pass the parameter (I.E. "Jurisdiction = '$(parJurisdiction)') with parJurisdiction set to the exact same value I get:
"Unclosed quotation mark after the character string 'SomeName County))'
Any suggestions as to how to solve this problem would be appreciated.
Thank you.
K
Best answer by joepk
I cannot help you with your actual question, but a workaround could be building your Where Clause in an attribute.
Use the Creator to create a null feature and a StringConcatenator to build the Where Clause. You can then use the feature as initiator for a FeatureReader and pass the Where Clause attribute as Where Clause.
joepk
Forum|alt.badge.img+22
  • Dec 22, 2023 3:30 PM UTC
garbadek
  • Dec 22, 2023 4:18 PM UTC
What wound up working was sort of a variation of @joepk​'s idea. I added an Attribute Manager after a Creator and just set an new attribute equal to the parameter value that contained the comma (,). Then I just substituted the new Attribute into the Where Clause rather than the Parameter and Bob's your uncle it works.
