Using a private SSH key with FTPCaller to authenticate an SFTP Connection hangs in FME Server
  • Feb 7, 2023 8:23 PM UTC
  • 5 replies
  • 361 views
mechilders11
Forum|alt.badge.img+3
As the directions in this topic detail:
https://community.safe.com/s/article/Using-a-private-SSH-key-with-FTPCaller-to-authenticate-an-SFTP-Connection-on-FME-Server-and-FME-Desktop
I am using a SystemCaller to launch Pageant and load the private keys so the FTPCaller can successfully authenticate a SFTP connection. This is working great in FME Desktop. However, when I load the workspace to FME Server, the SystemCaller just hangs. I have gone the extra step of even loading the keys in Pageant on the server, but still didn't help. Is there something extra that I must do to get this process to work on FME Server? I am using FME Desktop and Server 2022.1 Build 22618.
  • Feb 8, 2023 3:44 PM UTC
just to confirm, pageant *is* running on the server computer right? whats the command you're using in system caller?
start "C:\Program Files\PuTTY\pageant.exe" "c:\path\to\PRK.ppk"
 is what i am currently using on Server with no issues. make sure the user account for FME Server has permissions to read the file too.
mechilders11
  • Feb 8, 2023 3:53 PM UTC
Yes, I have pageant running (the icon is in the system tray) and I have loaded the key.
My system caller command is:
start "D:\\Program Files\\PuTTY\\pageant.exe" "C:\\FME\\Resources\\<retracted>\\SFTP\\CL_PrivateKey.ppk"
I am still investigating and would not at all be surprised if this is a permission issue as my company has EVERYTHING super locked down.
  • Feb 8, 2023 4:00 PM UTC
That was one of the road blocks I hit. The user account had no read privileges on anything so it just hung there trying to load it.
  • May 23, 2023 5:25 PM UTC
Hello, did you solve the problem? What is the solution ?
mechilders11
  • May 23, 2023 6:01 PM UTC
The problem has not been solved but it does appear to be a permission issue. We are in the process of upgrading our environment to 2023 (desktop and server.... well... form and flow) and that has slowed the implementation of this. I have been manually running it in the mean time.
