Updating ArcGis directly from SQL server
  • Feb 18, 2021 6:42 PM UTC
  • 42 views
I was looking into connecting directly SQL server to arcgis and ran into issues when using the update feature in the writer's field, can this be fixed? as when I have it on update I get number of errors, I have found a work around that issue by setting up insert and truncate features instead of update but this is taking too long, any idea why I the update feature is causing issues? and can it be fixed?
canerakin
  • Feb 28, 2021 4:14 AM UTC
Hey @zain​ ,
If I understand correctly. Your source data is SQL Server, the workbench pulls the information, makes some changes, and loads it into the geodatabase.
You can bring the geodatabase as a source and use the ChangeDetecter transformer.
For ChangeDetector Ports
  • Original - SQL Server
  • Geodatabase
Choose the ID for the attribute. I would generate a list of changes.
