Trying to figure out how to do a Server App with validation of user input (with FME Server 2022.2.3)
  • Mar 13, 2023 8:00 PM UTC
  • 6 replies
  • 158 views
mlupien
Forum|alt.badge.img+7
Trying to figure out how to do that with FME Server 2022.2.3
  1. Have the user fill a form ( my guess: Server App with User Parameters)
  2. Validate the data entered by the user (lookup into a database for existing value)
  3. If the data is good, process the data and confirm the user that the processing succeeded.
  4. If there are any errors in the user input, the user should be prompted to correct the input and submit for validation again.
  5. When data is submitted correctly, an email is sent to the supervisor with a link that will allow him to validate and complete extra data fields (such as authorization number)
I thought that I would be able to do this with Server Apps, Automations or Webhooks, but I can't figure out how to direct the user to a "second step" input .
Any Idea is welcome :)
Thank you.
Best answer by redgeographics
I think you can do that validation step within the workspace that's used for the Server App and then use a FMEServerJobSubmitter to start the workspace for step 3 & 5
If you have workspace 1 publish to a data streaming service you can have all the user communication in there. The only tricky bit would be step 4, but if you post a message instructing the user to go back to the initial form I think that could work.
Forum|alt.badge.img+63
itsmatt
Forum|alt.badge.img+48
  • Mar 14, 2023 2:23 PM UTC
If you're really clever the initial DataStreaming result could be a webpage (e.,g HTML) which has the ability to make a subsequent rest call to FME Server. But to be honest I think @Hans van der Maarel​ suggestion is enough
mlupien
  • Mar 14, 2023 4:16 PM UTC
Thank you, @Hans van der Maarel​ , for your reply.
I'll have a look to the FMEServerJobSubmitter. Is it only a background process or if it will give the user feedback ?
I may have a look to @virtualcitymatt​ suggestion too.
About Webhooks, is there a way to capture "currently logged in user" since it is using a Token ?
Thank you.
itsmatt
  • Mar 15, 2023 7:32 AM UTC
Thank you.
While I haven't tried it you can see if these give you what you're after. I suspect what is returned will be the owner of the token
Thank you.
The FMEServerJobSubmitter just submits the job, there's no feedback there
mlupien
  • Mar 17, 2023 7:38 PM UTC
Thank you for your answers,
I finally went with @Hans van der Maarel​  idea.
Only problem, so far is when I go back to my form, using the back button of my browser for example, the form is blank. Any Idea on how I could go back to the values that were entered by the user ?
Thank you again
