Translation fails when FME cannot delete temporary files
  • Jul 8, 2023 4:17 PM UTC
  • 202 views
I am running a translation in batch and it is failing when it attempts to cleanup temporary files. Is there a setting that will allow it to continue when this is encountered?
ERROR |Failed to delete the following files: 'D:\\Projects\\temp\\fctspatrel1688832115746_12608_1'. Please ensure that the files are not in use and that you have sufficient privileges to delete them.
ERROR |Failed to delete the following files: '%0'. Please ensure that the files are not in use and that you have sufficient privileges to delete them.
nielsgerrits
Forum|alt.badge.img+67
I have not seen this before, but my first guess would be a file scanning system, like a syncing system of a virusscanner, is reading the files while workbench tries to clean them.
timowalraven
Participant
  • Participant
  • Feb 28, 2024 3:02 PM UTC
@amyhex did you find a solution for this? I'm currently running into the same problem.
