Transformer to search for a value/regexp in any column
  • Jul 5, 2022 7:20 PM UTC
  • 90 views
hlouie
Forum|alt.badge.img+16
find in any columnI know StringSearch can look at that one selected column but I'm looking for a transformer that will search any column for a value? (similar way Visual Preview can find ??? in "any column")
muzhnasto
Forum|alt.badge.img+12
  • Jul 6, 2022 9:36 AM UTC
geomancer
Forum|alt.badge.img+71
  • Jul 6, 2022 10:08 AM UTC
Can you combine all attributes in a new attribute (using StringConcatenator or AttributeCreator or AttributeManager), placing a separator character between the different attribute values, and search the resulting attribute?
Combine_Attributes
nielsgerrits
Forum|alt.badge.img+67
If you also need the corresponding column name and / or you want to make it dynamic you can use the AttributeExploder to create a feature for each attribute and search in _attr_value.
Edit: this is the way the GlobalStringSearcher from the hub works.
