Transfor Date String from 'YYYY-MM-DD' to Date String 'DD/MM/YYYY'
galigis
Forum|alt.badge.img+20
HI All,
Any workaround to convert a date string (YYYY-MM-DD format) to DD/MM/YYYY ? The field type needs to stay as date string see below:
I've tried a few transformers (StringReplacer + ListExploder+ String Concatenator) but couldn't get it to work and show 21/04/2023
Thanks
connecter
Forum|alt.badge.img+10
  • April 23, 2023
Hi @galigis​ ,
Have you already tried the DateTimeConverter with the following settings?
galigis
  • April 23, 2023
Thanks @connecter​ - Yes, I have but fme gives me a rejection code 'INVALID_INPUT', see below:
hkingsbury
Forum|alt.badge.img+56
  • April 23, 2023
Before you pass the features into the DateTimeConverter, what does fme show the value to be? I'm wondering if ArcGIS is doing some conversion when showing the date
galigis
  • April 24, 2023
Hi @hkingsbury​ - FME shows the Model_Date as 'YYYY-MM-DD' as string and ArcGIS is also treating the fields as string.
Over the weekend I came up with the solution, maybe isn't the most elegant workaround ever....but does the job :),
Here are the transformers used:
1- StringReplacer to replace '-' to '/'
2- AttributeSplitter to split filed by '/'
3- ListExploder
4-Sorter to sort the list values
5- (3) Testers to filter the element_indexes (day (2), month (1), year (0))
6- AttributeCreator to create 'Day', 'Month', 'Year' fields.
7- Feature Merger to join Day & Month by OBJECTID.
8- Feature Merger to join Month & Year by OBJECTID.
9- StringConcatenator to concatenate day, month, year
10- AttributeKeeper to keep the most important fields.
Any better workaround, please let me know! 🙂
Thanks
hkingsbury
  • April 25, 2023
Based on the above, you should be able to use the solution provided by @connecter​ .
Can you provide a sample of the data?
