Training postGIS database down? Cannot connect to sample postGIS database (postgis.safe.train.com) to complete FME Academy Trail Integrate Data with the FME Platform.
  • December 29, 2022
  • 8 replies
  • 151 views
100 % new to FME and FME Academy. As a new user I have started my first trail, Integrate Data with the FME Platform. The third Module, Transform Data, has the student connect to a postGIS database, called fmedata at: I have tried this as documented, but get no response. A ping to this returns: Pinging ec2-54-214-172-21.us-west-2.compute.amazonaws.com [54.214.172.21] with 32 bytes of data:
Request timed out.
Is the database available?
danilo_fme
Forum|alt.badge.img+57
Hi @dwinvegas​
I created this connection without error here in my note.
Connection
Please, could you check it todat in your FME?
Thanks in Advance,
Danilo
This still does not work for me. I am using FME Workbench 2021.2
FME(R) 2021.2.2.0 (20220106 - Build 21806 - WIN64)
The instructions of the exercise, Quickly Create a Conversion Workflow
(https://safe.my.trailhead.com/content/safe/modules/transform-data/quickly-create-a-conversion-workflow?trail_id=integrate-data-with-the-fme-platform) , are to generate a workspace using Generate Workspace and a postGIS reader.
I have tried to replicate your solution using a postgresql reader with the same or similar result. Perhaps my IT security group is stopping this connection?
My Error Log as follows:
Creating reader for format: PostgreSQL
Trying to find a DYNAMIC plugin for reader named `POSTGRES'
Loaded module 'POSTGRES' from file 'C:\\Program Files\\FME\\plugins/POSTGIS.dll'
FME API version of module 'POSTGRES' matches current internal version (3.8 20210302)
Opening POSTGRES reader for dataset 'fmedata'
Is the server running on host "postgis.train.safe.com" (54.214.172.21) and accepting
TCP/IP connections on port 5432?
Successfully closed POSTGRES database reader
UniversalReader -- readSchema resulted in 0 schema features being returned
Reader Parameter(0) = >fmedata<
Reader Parameter(1) = >HOST<
Reader Parameter(1) = >postgis.train.safe.com<
Reader Parameter(3) = >PORT<
Reader Parameter(3) = >5432<
Reader Parameter(5) = >USER_NAME<
Reader Parameter(5) = >fmedata<
Reader Parameter(7) = >PASSWORD<
Reader Parameter(7) = >********<
Reader Parameter(9) = >SSL_OPTIONS<
Reader Parameter(9) = ><
Reader Parameter(11) = >SSLMODE<
Reader Parameter(11) = >prefer<
Reader Parameter(13) = >CA_CERTIFICATE<
Reader Parameter(13) = ><
Reader Parameter(15) = >CLIENT_CERTIFICATE<
Reader Parameter(15) = ><
Reader Parameter(17) = >CLIENT_PRIV_KEY<
Reader Parameter(17) = ><
Reader Parameter(19) = >SSL_PASSWORD<
Reader Parameter(19) = >********<
Reader Parameter(21) = >RETRIEVE_ALL_TABLE_NAMES<
Reader Parameter(21) = >YES<
Reader Directive(0) = >HOST<
Reader Directive(1) = >postgis.train.safe.com<
Reader Directive(2) = >PORT<
Reader Directive(3) = >5432<
Reader Directive(4) = >USER_NAME<
Reader Directive(5) = >fmedata<
Reader Directive(6) = >PASSWORD<
Reader Directive(7) = >********<
Reader Directive(8) = >SSL_OPTIONS<
Reader Directive(9) = ><
Reader Directive(10) = >SSLMODE<
Reader Directive(11) = >prefer<
Reader Directive(12) = >CA_CERTIFICATE<
Reader Directive(13) = ><
Reader Directive(14) = >CLIENT_CERTIFICATE<
Reader Directive(15) = ><
Reader Directive(16) = >CLIENT_PRIV_KEY<
Reader Directive(17) = ><
Reader Directive(18) = >SSL_PASSWORD<
Reader Directive(19) = >********<
Reader Directive(20) = >RETRIEVE_ALL_TABLE_NAMES<
Reader Directive(21) = >YES<
POSTGRES reader: Reader failed in open() call
Hi @dwinvegas​
Connection
Thanks in Advance,
Danilo
Good Morning, I have tried to do just as you show. I had another failure. I replied in the forum with full details and my error log. I suspect that my IT security group has some policy that is blocking the connection. Thanks Dave
danilo_fme
It's very strange. Mayb we can do a meeting online to try to see the error.
ryanatsafe
Forum|alt.badge.img+11
When I encountered the error on my system last year, a reboot fixed it. Please try rebooting your system and see if that resolves the issue. If not, please let me know if you are using a VPN.
Experiencing the same problem
Hello, am also experiencing the same problem not being able to connect to postgis.x.x.x etc
ryanatsafe
Check if you are using a VPN, and try rebooting your machine. I've found that some VPNs can cause an issue, and disconnecting and/or rebooting my machine resolved the issue.
