SystemCaller command 'query user' throwing error
  • Aug 24, 2023 7:28 PM UTC
  • 5 replies
  • 137 views
australgis
Forum|alt.badge.img+3
SystemCaller command 'query user' works perfectly well on Windows CMD command prompt but throw an error on workbench:
SystemCaller: Failed to Execute `query user'
There is something wrong with my syntax or this is just a bug?
I am running FME 2022.1 by the way.
DanAtSafe
Forum|alt.badge.img+23
  • Aug 24, 2023 8:20 PM UTC
Hi @australgis​ Are you getting an error or just a warning? I get a warning too but if I redirect the output to a file then I see that it worked. See https://community.safe.com/s/question/0D54Q000080hVEXSA2/is-it-possible-to-run-a-command-line-command-in-fme and https://community.safe.com/s/question/0D54Q000080hf1MSAQ/return-result-in-attribute-with-systemcaller for more examples using the SystemCaller.
australgis
  • Aug 24, 2023 8:29 PM UTC
The message belongs to the category Information, but as it says "Failed" and SystemCaller sends an Error Code : 1. I just wanted to know exactly why exactly fails.  The command actually works but sends a fail message. Should I just ignore it? Seems like a bug to me.
2023-08-24 16:22:24|   0.7|  0.0|WARN  |SystemCaller: Failed to Execute `query user /server:myserver>>C:\temp\HealthCheck\Myserver.txt'
DanAtSafe
  • Aug 24, 2023 9:32 PM UTC
@australgis​ I've filed FMEFORM-29308 about this incorrect warning message.
australgis
  • Aug 24, 2023 11:42 PM UTC
Thank you!
DanAtSafe
  • Sep 13, 2023 4:21 AM UTC
Hi @australgis​ FMEFORM-29308 has been fixed for FME 2023.2 (not yet available). 'query' seems to always return an error level of 1, regardless of the result.  The fix is that FME will now INFORM rather than WARN:
SystemCaller: Command '"query user >> "C:/Users/...\user620.txt""' exited with status '1' which may indicate an error
