Sum attributes for each record
  • Nov 4, 2020 11:37 AM UTC
  • 428 views
markcoopersdc
Hi
I have a database which has about 80 attributes that I need to add together. Short of manually creating an attribute in Attribute Manager's arithmetic editor, is there another way that can sum there? I thought about creating a list, but that creates a numbered element per feature, not per field like I need.
Many thanks
Mark
Forum|alt.badge.img+54
  • Nov 4, 2020 11:46 AM UTC
Assuming this is what you are after, so adding up multiple attributes from the same feature
Capture
Inefficient way
  • Use AttributeExploder to explode the attribute into features per attribute
  • Get rid of any features that contain an AttributeName you don't want to sum (e.g. format attributes)
  • Aggregate based on some original record id and sum AttributeValues
Efficient way
  • Use python
Another way
  • If all the attributes you want to sum share a common prefix, you can use a ListPopulator to build a list followed by a ListSummer. You can use a bulk attribute renamer to add the prefix if it doesn't already exist and remove again later
  • Nov 4, 2020 11:58 AM UTC
Capture
Inefficient way
Efficient way
  • Use python
Another way
Actually the ListPopulator doesn't appear to work correctly with a BulkAttributeRenamer in front of it...
bwn
Forum|alt.badge.img+26
  • Nov 5, 2020 10:50 AM UTC
What about with ListExpressionPopulator instead? I'm sure I've done the same technique like this in a workspace with BulkAttributeRenamer + ListExpressionPopulator?
