Spatial Join: one to one
  • Mar 21, 2023 8:50 AM UTC
  • 141 views
there are lots of qstns about one to many joins.
I want to understand what transformer to use to achieve a one to one spatial join based on geometry?
I have a line in GIS that I want to analyse to see if there a geometry join to a line in CAD. This works fine with the SpatialFilter if there is only one line.
however when GIS and CAD has two lines in close proximity the SpatialFilter is creating a many to one join by joining the Two GIS lines to the same CAD line.
How do I create the one to one join please?
thanks in advance
nielsgerrits
Forum|alt.badge.img+67
Do you want to check if two lines from different sources are the same? One way to do this is to use the Matcher transformer.
The ChangeDetector is probably a more intuitive way to do this.
@tammydovey​ Did you try SpatialRelator. This will give you a list of all the lines that touch. There's a article on Spatial Joins that give the options for joining spatial data and also a nice webinar
