SOAP API not working in FME
  • Apr 18, 2023 7:42 PM UTC
  • 122 views
Hi all!
I want call a soap service in FME. I use this link:
https://swea.riksbank.se/sweaWS/wsdl/sweaWS_ssl.wsdl
I used the program SoapUI to generate and test the xml request. In SoapUI the return works fine. This is the request I use:
<soap:Envelope xmlns:soap="http://www.w3.org/2003/05/soap-envelope" xmlns:xsd="http://swea.riksbank.se/xsd">
  <soap:Header/>
  <soap:Body>
     <xsd:getMonthlyAverageExchangeRates>
        <year>2022</year>
        <month>1</month>
        <languageid>en</languageid>
     </xsd:getMonthlyAverageExchangeRates>
  </soap:Body>
</soap:Envelope>
However, in FME I only get a list of function as a return.
Any help is welcome.
Thanks in advance!Request and return in SoapUI
Best answer by david_r
Make sure to use the same content-type as in SoapUI, look under the "Raw" tab of the request:
imageIn FME:
imageSee also this article: https://community.safe.com/s/article/working-with-soap-services
  • Apr 18, 2023 8:05 PM UTC
imageIn FME:
imageIn FME:
Thank you so much @david_r​ !
I added the conten type. Moreover, I realized that I used the wrong url. I took the wsdl instead!
Now it works!
Thanks again for your help!
