SharePointOnineConnector - Custom columns
  • Sep 17, 2020 8:43 AM UTC
  • 5 replies
  • 133 views
roberto
I'm performing some tests with the SharePointOnlineConnector. It works well uploading files. I'm not able to write some fields in the document library. Do you think it is possible? If yes, how to do it?
Thanks
Roberto
  • Sep 17, 2020 8:57 AM UTC
For custom columns you'll have to write the metadata manually using the HTTPCaller with authentication set to an MS Graph web connection (that you'll have to configure first).
You'll then want to use the PATCH method on a URL that looks like this:
https://graph.microsoft.com/v1.0/sites/<siteid>/lists/<listid>/items/<listitemid>/fields
The message body should contain a JSON document describing the values you want to set, see: https://docs.microsoft.com/en-us/graph/api/listitem-update?view=graph-rest-1.0&tabs=http
I believe that the SharepointOnlineConnector will let you retrieve these IDs from the output port after uploading the file.
This is for updating "regular" column values, if have managed metadata columns, then that's a fair bit more complex.
roberto
  • Sep 17, 2020 9:49 AM UTC
Thanks @david_r,
I'll work on that solution and let you know.
Regards
Roberto
roberto
  • Sep 23, 2020 7:49 AM UTC
Hello @david_r​ ,
I'm trying to follow your hint. Creating a new web connection (Microsoft OneDrive - Graph) with my credentials and building the url with list_id and item_id out from the  SharePointOnlineConnector transformer, I always receive the error 'HTTP/1.1 404 Not Found'. Navigating the url that is shown close to the error, I see a response with "code":"InvalidAuthenticationToken" and "message":"Access token is empty".
Any further suggestion?
TIA
Roberto
  • Sep 23, 2020 9:45 AM UTC
Hello @david_r​ ,
TIA
Roberto
I suspect that you shouldn't be using the MS OneDrive connection. If you haven't already, try installing and configuring this web connection:
https://hub.safe.com/publishers/gerhardatsafe/web-connections/microsoft-graph
Don't forget to replace the Client ID and Client Secret with your own values, as defined in the Sharepoint console when granting API access.
roberto
  • Oct 6, 2020 5:54 PM UTC
Hello @david_r​ ,
TIA
Roberto
Hello @david_r​ ,
maybe I need more expertize on graph concept. I configured the fme_graph web connection with the information needed. But, for sure with some errors. Testing the connection, it seems that the token retrieval is fine but not the token refresh.
Capture1
Maybe the redirect_uri?
Thanks
Regards
Roberto
