Replace text as number
  • October 12, 2020
  • 109 views
user01
Hello,
I have a text format attribute (lenght : 5 characters (for exple : FEFER, FOUSER,...)) as primary key and I want to change it in integer attribute format. Do you know about methods to do it ? I've tried ASCII conversion but it gives results more than the integer limit.
For exemple : I thought I could change each letter by the number (A->1, B->2, ...). How can I do it ?
Thank you for your help.
Forum|alt.badge.img+53
You'll need to split the attribute using an AttributeSplitter so you get the individual letters, then use a CharacterCodeExtrator to turn them into their ascii codes and a StringConcatenator or AttributeManager to create a new attribute that holds those 5 ascii codes.
ZZZZZ would give you 9090909090 which is indeed longer than the max length of a regular 32-bit integer. Does your output format support 64-bit integers (as primary keys)?
user01
  • October 12, 2020
My output format is 32 bit.
I have found the BaseConverter Transformer. I have converted base 64 to base 10. It works !
