Replace data in a geodatabase
  • Mar 8, 2022 9:15 PM UTC
  • 297 views
Forum|alt.badge.img+3
I have an SDE geodatabase. I need to load a shapefile and replace all of the data in a layer with the new data coming in. For example there is a roads layer in the geodatabase and once a month I get a new roads layer. I'm looking to just replace the entire layer and add the new data that I have received in a shapefile format. Is there an easy way to do this?
warrendev
Forum|alt.badge.img+28
  • Mar 8, 2022 11:11 PM UTC
Since you are replacing the data each time, you might look into setting the SDE writer to "truncate existing" which will remove all existing data and load the new data into that feature class.
ingalla
Forum|alt.badge.img+10
  • Mar 9, 2022 7:50 AM UTC
I agree with @Chris Warren​ set the writer to truncate existing. This will keep the table structure as is, remove the existing data and then insert your new data into the table....
ingalla
  • Mar 9, 2022 3:51 PM UTC
If you click on the cog within the writer you will see the properties. The truncate existing can be found in the General / Table Handling section
featuretype
  • Mar 14, 2022 3:57 PM UTC
Thank you that worked!
