removing typos & matching meter IDs from two different datasets
  • May 5, 2023 8:20 AM UTC
  • 61 views
grayson
Forum|alt.badge.img+7
Basically, I want to match meter IDs from two different datasets: shapefile and excel file.
Meter IDs in both datasets might have typos such as dashes, dots, letters, slashes, which I need to remove first.
Then I want to match MTR_NO from Excel against Mother_1 , Child_3, & Child_4. My idea is to export an excel table that will include only matching meter IDs.
Zrzut ekranu 2023-05-05 101140
Best answer by ebygomm
You could use a StringReplacer to replace anything that is not a number with nothing to get just the numeric meter id
Mode: Replace Regular Expression
Text to Replace: [^\\d]
Replacement Text:
Forum|alt.badge.img+54
  • May 5, 2023 8:44 AM UTC
Replacement Text:
grayson
  • May 8, 2023 6:00 AM UTC
Thanks, it helped! :)
