Removing keyword based on the value of another column
calvin.fme
Hi all,
I am trying to remove some keywords based on the value of another column.
What I am hoping to achieve:
Removing Oxley & Victoria in Column A
Can anyone please provide some assistance.
Thanks
Best answer by gav
Hi @calvin.fme​  - If you know the formatting will be consistent (for example, only 1 space after the value in Column B), you can use a StringReplacer and set the Attribute to "Column A", Mode to "Replace Text" and Text To Replace to "@Value(B) " (Don't forget the space). Screenshot below.
StringReplacer - Replace Text
gav
Forum|alt.badge.img+10
  • July 25, 2022
calvin.fme
  • July 25, 2022
Thank you so much @gav​. It worked!
gav
  • July 25, 2022
Rock on!
