Removing all spaces in an attribute
  • January 13, 2023
  • 451 views
rmpayaby
Forum|alt.badge.img+3
I am working on two excel-files that I wanted to merge with address.
Unfortunately I am struggling to merge with the address since they are formatted differently for each excel file.
For example: Alex Olssons Road 50 - Alex Olssons road 50
There are more strange cases where there are lower and upper case letters between each spaces. I wanted change the attribute for addresses in both files so that all the letters are in uppercase and all spaces are removed to make it easier to merge.
For example: ALEXOLSSONSROAD50
Any ideas what transformer I should use?
dustin
Forum|alt.badge.img+31
  • January 13, 2023
You can use the StringReplacer. Just type a space in the Text to Replace parameter. Another method if you prefer: I'm assuming you are using the FeatureMerger? If so, you can use this expression in the Requestor and Supplier parameters to assume everything is uppercase and also remove spaces before the comparison (att being your attribute). That way you don't actually have to modify the value.
@ReplaceString(@UpperCase(@Value(att))," ","")
