Remap ranges (normalize) different elevation/ Heightmaps.
  • Sep 29, 2021 2:20 PM UTC
  • 148 views
Hello, i got this issue when using heightmaps (REAL32), they seem to not have the same range / offsets in each map, look at the example below. there are 4 maps, which should tile, but doesnt.
Is there someway to remap each maps data to the same ranges? any ideas? or should i just request a new set of data?
 Example
jdh
Forum|alt.badge.img+41
  • Sep 29, 2021 6:28 PM UTC
Do you have any data on what the real world elevation values are for the individual tiles?
a heightmap is usually stretched to 16 bits, so if the elevation range was 52m to 3600m it would have different pixel values than if it were 1 to 1250m.
