Rejected Feature Handling: Continue Translation ignored when running with feature caching enabled
  • Apr 9, 2019 9:01 PM UTC
  • 1984 views
Getting failure from a <rejected> feature even though Rejected Feature Handling: Continue Translation selected:
2019-04-09 14:03:26|1543.0| 0.0|ERROR |FeatureMerger_2_<Rejected> (TeeFactory): FeatureMerger_2_<Rejected>: Termination Message: 'FeatureMerger_2 output a <Rejected> feature. To continue translation when features are rejected, change 'Workspace Parameters' > Translation > 'Rejected Feature Handling' to 'Continue Translation''
2019-04-09 14:03:26|1543.0| 0.0|ERROR |FeatureMerger_2_<Rejected>: Termination Message: 'FeatureMerger_2 output a <Rejected> feature. To continue translation when features are rejected, change 'Workspace Parameters' > Translation > 'Rejected Feature Handling' to 'Continue Translation''
I ran the fmw twice and got the same result. Here's my log up to the point of failure, if you're curious...Log with Feature Caching.txt
jovitaatsafe
Forum|alt.badge.img+11
Hi @pvaziri,
I did a bit of digging and it looks like there is a difference between setting rejected feature handling in the Workspace Parameter Defaults where you are setting it, and setting it in the Workspace Parameters as Runtime options.
When setting the Workspace Parameter Defaults, this setting is used when you create a new workspace. The runtime option however can override this setting as the current user. To set the runtime option, you can go to the Navigator > Workspace Parameters > Translation > Rejected Feature Handling to set it to continue translation. Hope that helps!
  • Apr 10, 2019 3:30 PM UTC
Hi @pvaziri,
It helps, although it is confusing and can lead to an unexpected error. Shouldn't the higher level FME Options setting override the Workspace Parameter (especially since that setting is referenced in the log). If it should work the other way (Workspace Parameter over FME Options setting), then what is presented in the log reflects what setting is causing the problem.
