Redock my Visual Preview window in FME Workbench 2020.0 for Mac OS
  • Aug 3, 2021 8:21 PM UTC
  • 171 views
I'm having the same problem as the user here, but I'm using 2020.0.3.0 (20200605 - Build 20252 - macosx). Hove can I redock my Visual Preview window after accidentally undocking it? Hovering isn't working.
Forum|alt.badge.img+63
Not even if you drag it all the way down (below the horizontal scrollbar of the main canvas)?
  • Aug 4, 2021 9:54 PM UTC
Thank you @Hans van der Maarel​ ! For some reason this worked, but only after I restarted my my computer. Just restarting the application didn't seem to help.
daraghatsafe
Hi @hmac​ I spoke to the dev team about this. Seems like it was an issue in the early releases of 2020 but it was resolved in later builds like 2020.2 for example.
Glad to hear that this issue is resolved now.
  • Aug 5, 2021 5:59 PM UTC
@daraghatsafe​ - Thank you ... good to know! I should probably upgrade (straight to 2021 at this point)
