Read xml/pbf file after HTTP caller
  • May 18, 2019 3:11 AM UTC
  • 110 views
scobierob
I have been using FME for some simple tasks but I would like to take it to the next level. I have workbench is a simple conversion from .pbf format and it loads this information into a geodatabase.
Next up I would like to have this workbench download an updated pbf file before it starts the conversion.
Is there a way to run an HTTPCaller and then automatically read a file that is downloaded from this transformer within a workspace? I am not sure how I would connect the output of the HTTPcaller so that is readable within my workspace.
Best answer by takashi
If you downloaded a file with the HTTPCaller, the output feature would have an attribute (named "_response_file_path" by default) that stores the file path. A possible way to read the file is: connect a FeatureReader to the HTTPCaller output port and set the file path attribute to its Dataset parameter.
  • May 18, 2019 5:09 AM UTC
