Read particular geometry type form gdb
  • Nov 21, 2023 3:01 PM UTC
  • 5 replies
  • 111 views
marta.podsiad
Forum|alt.badge.img+12
Is there a way that I can read only point layer type from gdb without reading the full content first and then making selection?
nielsgerrits
Forum|alt.badge.img+67
One way to do this:
  • Creator
  • FeatureReader, read GDB, schema only.
  • Filter featureclasses with point geometrytype.
  • FeatureReader, initiated by previously filtered features, read these featureclasses.
marta.podsiad
  • Nov 22, 2023 7:52 AM UTC
One way to do this:
  • Creator
Unfortunately, I cannot make it work. If, in FeatureReader is read only Schema, the information about geometry is lost. That approach also does not work with geodb_relationship as it does not have schema.
My goal is to read only geodb_relationship from gdb without reading all the data
nielsgerrits
That is an entirely different question :) I don't think you can read a relationship class using FME.
But if I read the schema of a featureclass from a file geodatabase, I see the attribute
fme_geometry{0} (string: UTF-8): fme_point
in the Feature Information window. So I do not think this info can't be read.
marta.podsiad
  • Nov 22, 2023 2:37 PM UTC
I was thinking about using Python Script in Features to Read section of the Reader to read only the geodb_relationship from gdb but I have very basic knowledge about this scripting language
nielsgerrits
If I select a relationship class from a gdb in a featurereader manually, it does not output any features, so I suspect this is not supported.
