python error merger
  • Jan 22, 2024 1:13 PM UTC
  • 81 views
bertdrenth
I have a question, i am trying to join in a pythoncaller
Only i am getting this error:
BADNEWS: Cannot convert null string into an integer
(C:\code\fme\foundation\framework\util\stf\stfutil.cpp:347) class StatusInfo *__cdecl STF_stringToUInt(const class ObsoleteString &,unsigned int &)
Python Exception <AttributeError>: 'fmeobjects.FMEFeature' object has no attribute 'getAllAttributes'
Traceback (most recent call last):
 File "<string>", line 14, in input
AttributeError: 'fmeobjects.FMEFeature' object has no attribute 'getAllAttributes'
Error encountered while calling method `input'
PythonCaller_FeatureMergerReplacement (PythonFactory): PythonFactory failed to process feature
The script i am using is:
import fme
import fmeobjects
import pandas as pd
class FeatureMergerReplacement(object):
    def __init__(self):
        # Initialiseer de DataFrames
        self.primary_df = pd.DataFrame()
        self.secondary_df = pd.DataFrame()
    def input(self, feature):
        # Voeg rij toe aan primary_df
        new_row = pd.DataFrame([feature.getAllAttributes()], columns=feature.getAllAttributeNames())
        self.primary_df = pd.concat([self.primary_df, new_row], ignore_index=True)
    def input2(self, feature):
        # Voeg rij toe aan secondary_df
        self.secondary_df = pd.concat([self.secondary_df, new_row], ignore_index=True)
    def close(self):
        # Voer de join-operatie uit
        self.merged_df = pd.merge(self.primary_df, self.secondary_df, on='ObservationID', how='inner')
        # Itereer over elke rij in het resultaat en stuur terug naar FME
        for index, row in self.merged_df.iterrows():
            feature = fmeobjects.FMEFeature()
            for col in self.merged_df.columns:
                feature.setAttribute(col, row[col])
            self.pyoutput(feature)
  • Jan 22, 2024 1:47 PM UTC
Firstly, when posting Python code, can you please format it using the "Code snippet" function:
imageIt makes a big difference in readability.
Secondly, to the error message itself, there is no method called "getAllAttributes" in the FMEFeature class definition, see https://docs.safe.com/fme/html/fmepython/api/fmeobjects/_feature/fmeobjects.FMEFeature.html
You can try to use a list comprehension if you need all the values from all the attributes, e.g.:
new_row = pd.DataFrame([feature.getAttribute(x) for x in feature.getAllAttributeNames()], columns=feature.getAllAttributeNames())
  • Jan 22, 2024 1:51 PM UTC
Also, I'm not quite sure how "input2()" ever gets called?
