Published parameters and date range filter
  • Feb 8, 2023 12:30 AM UTC
  • 96 views
nicholas
Forum|alt.badge.img+14
I have a workbench with two public parameters, start_date and end_date
I want to filter records on a date attribute. Values like "20220509213856"
Except, I want the actual range to be two days before the chosen start_date and two days after the chosen end_date.
How do I set up the Tester?
Forum|alt.badge.img+63
You can use a DateTimeCalculator to calculate the new start and end dates, then use a Tester to see if the date attribute is higher than the start date and lower than the end date. This particular date/time notation has the benefit of being a number, so you can do regular math on it.
