Problem with AttributeFileWriter
  • Jun 2, 2021 11:05 AM UTC
  • 140 views
scarter
Forum|alt.badge.img+10
I'm trialling AttributeFileWriter to output a list of values from a table from a specified attribute field. In theory AttributeFileWriter seems to be ideal for the task.
I've read in the source data which has 13 records. I want to create a .txt list of all the application numbers from the 'application_number' field.
There are no duplicate application numbers in the source data so I'd expect an output of 13 applications numbers in the .txt.
In AttributeFileWriter I've set the Source Attribute to application_number. But when I view the output .txt only one application numbers is listed, and not 13 as expected.
Any ideas as to why this is?
  • Jun 2, 2021 11:40 AM UTC
Is the AttributeFileWriter configured for appending or replacing content?
Also, why not use a FeatureWriter with the Text File writer? https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/textline/TEXTLINE_writer.htm
scarter
  • Jun 2, 2021 11:54 AM UTC
Thanks for that, david_r. I switched to ‘Append to file’ and it now produces all 13 values. Great. Is there a way of adding a delimiter to the outputted values? Or is there a way of outputting as a list? So instead of… value_1 value_2 value_3 value_4 value_5 value_6 value_7 value_8 value_9 value_10 value_11 value_12 value_13 I would get… value_1; value_2; value_3; value_4; value_5; value_6; value_7; value_8; value_9; value_10; value_11; value_12; value_13 or to get… value_1 value_2 value_3 value_4 value_5 value_6 value_7 value_8 value_9 value_10 value_11 value_12 value_13 Thanks, value_1 value_2 value_3 value_4 value_5 value_6 value_7 value_8 value_9 value_10 value_11 value_12 value_13
  • Jun 2, 2021 11:59 AM UTC
My recommendation is to replace the AttributeFileWriter (which is a specialty one-trick-pony transformer) with the much more powerful FeatureWriter. Specifically, look into using either the Text File or the CSV writer.
The AttributeFileWriter is not really meant for what you're trying to accomplish.
scarter
  • Jun 2, 2021 3:21 PM UTC
OK, thanks. That works much better.
