Objects in this class cannot be updated outside an edit session (ArcGis SDE)
  • October 22, 2020
  • 901 views
fme_hans
Forum|alt.badge.img+5
With FME I want to update one column of an ArcGis sde data table. The table is a non versioned feature class with enable archiving and an active service has been created.
I get the following error:
I have tried all the different transaction types of the writer but it makes no difference.
What could it be?
Greatngs, Hans
Best answer by oscard
Does the user you are using to update the feature class have edit capabilities?
oscard
Forum|alt.badge.img+21
  • October 22, 2020
fme_hans
  • October 22, 2020
Yes i have edit capabilities.
fme_hans
  • October 22, 2020
Oscard, you are right. I changed to an other user and now i can write.
Thanks, it is solved
oscard
  • October 22, 2020
I'm glad it's working for you now! :)
