Multiline string to Linestring
  • Dec 7, 2023 2:41 PM UTC
  • 14 replies
  • 898 views
Hello,
I have lines (linestring) that intersect forming Multilinestring. I would like to know if it possible to "force" them to keep the Linestring format?
Example: here is a network with a loop (in red)
imageOn FME, I tried a deagregator which gives me 3 polylines , 3 linestring. Ok it's good! But I want juste one line and impossible for me to find how to merge these 3 lines without convert all in Multilinestring.
I tried the LineCombiner but nothing happens, I still had my 3 lines.imageAny help would be appreciated :)
Thanks you
Best answer by panda
In the linecombiner, you group by the attribute idchemin, so all 3 lines have the same attribute? Just checking. Can you upload an FFS with the 3 lines? Difficult to say what is wrong from printscreens.
single-line@kael112 I finally got it drawn correctly yay! However, I have not quite figured out how to make this dynamic. I have to manually rearrange the part number to get this to work. I have attached fme workspace with annotations to help explain what I did. Please let me know if you figure out how to make it dynamic!
nielsgerrits
Forum|alt.badge.img+67
If the vertices of the endpoints of the lines are not on exactly the same location, the LineCombiner will not connect them. You can try to fix this using the Snapper transformer upstream of the LineCombiner.
  • Dec 7, 2023 4:32 PM UTC
great Idea but the problem still here!
nielsgerrits
  • Dec 8, 2023 8:16 AM UTC
Yes it's the same.
I uploaded a FFS, thank you for your help
nielsgerrits
I now better understand your issue. The line is self intersecting, creating 3 parts due to the self intersect. I do not have a solution now but someone else probably has.
2023-12-08_09h33_52
  • Dec 11, 2023 1:29 PM UTC
Yes the self intersecting create 3 parts. I Would like to know if it's possible to "force" the line ,don't create the 3 parts, still have just one line?
If somebody has an idea ... 😊
panda
Forum|alt.badge.img+20
  • Dec 15, 2023 3:35 PM UTC
  • Dec 19, 2023 3:07 PM UTC
Thank you @panda​ , it works!
  • Jan 8, 2024 10:56 AM UTC
@panda​
your script works fine in a one way but how to do in a round trip. I tried and this is the result
imageimageDo You know a way to do this?
thank you
panda
  • Jan 8, 2024 4:35 PM UTC
@panda​
thank you
Do you mind provide me the .ffs for those feature please.
  • Jan 9, 2024 9:40 AM UTC
Here you will find a line which is in fact two compiled lines (the forward and the return)
Thank you for your help
panda
  • Jan 9, 2024 10:51 PM UTC
So I personally never deal with road network before. The way I do it may be wrong. But I think the issue is at this location.OriginalIntersectI'm wondering if you can fix these verticies manually. I'm not quite sure how to remove some of these verticies in FME without spend couple more hours on it. I remove some of the verticies in the middle and move each of the line end vertex to make it connect without intersect each other. I'm not sure if this is the acceptable way to make road network. But this way it fixed the multipart line and turn it into single line with the same exact workspace i provided before.
intersect
  • Jan 10, 2024 11:17 AM UTC
I'm agree with you, it requests hours and manuel work to get a perfect network.
Thank for your help.
panda
  • Jan 10, 2024 3:33 PM UTC
Let me know if the way I fix it is how it is supposed to be? When I have free time, I'll work on this. I imagine I will eventually run into this issue at some point.
