Move workspaces to a different repository in FME Server
vxn43
Forum|alt.badge.img+18
I have 2 workspaces in the Workspaces - Test Repository. I want to move them to a different folder. In the Test Repository, I checked the box to the left of the workspace name, and under Actions there is no option to move a workspace to a different folder. What is the best way to achieve this?
Best answer by redgeographics
Download and re-publish to a different repository is unfortunately still the way to go I'm afraid. There's an idea to make this easier: Copy/Move workspaces to other repository, if you vote for that it'll increase the chance of it being implemented.
There should be a way to do it via the Rest API if the workspace is really simple and doesn't use anything difficult like a custom transformer, web connection etc. From the Rest API documentation (/repositories/< repository >/items endpoint, Publish a single item to a repository
Publishes a single item to a repository. The file name must be specified in the 'Content-Disposition' header. Note that this endpoint does not support the following: Publishing data files, custom transformers, database connections, web connections, or packages associated with workspaces. To publish workspaces to FME Server with support for any of these features, use the "Publish to FME Server" wizard from the FME Desktop Workbench. For more information, see "Publishing to FME Server" in the FME Desktop Help.
Forum|alt.badge.img+50
  • July 18, 2023
vxn43
  • July 18, 2023
Thanks, I voted for it. Looks like it has been in the idea space for 6+ years, hope they implement this idea someday.
