Merging a UINT8 attribute with a UINT64 attribute output an UINT8 attribute that goes beyond 255.
  • Mar 2, 2021 6:06 PM UTC
  • 0 replies
  • 30 views
I have two CSV readers containing the same informations but with different range of value.
Let's say that I have something like this:
Reader_1:
[ATTRIBUTE_1](UINT8)
[ATTRIBUTE_2](DOUBLE)
And
Reader_2:
[ATTRIBUTE_1](UINT64)
(FME has choosed the datatype automatically)
Since both reader have the same attribute's name, I connect both reader's output to a "sorter" transformer.
And here, a weird thing happens, the sorter output ATTRIBUTE_1 as UINT8 (I expected that FME would choose the biggest datatype, not the smallest one).
But some value are bigger than 255:
CaptureIs that a miracle ?
Then I use a StatisticCalculator to find the max value of ATTRIBUTE_1 group by some other attributes and the output is, this time, limited to 255.
So why FME do not pick the biggest datatype ? How can a FME_UINT8 variable be bigger than 255 and what can I do to calculate my statistics correctly ?
Of course I can manually change the ATTRIBUTE_1 datatype, but that does not explain that weird behaviour. (BTW I'm using FME 2020.0 Build 20238)
