KML to shape conversion and extracting specific information from KML
  • Aug 20, 2020 10:04 AM UTC
  • 255 views
gis2020
Forum|alt.badge.img+5
Hi All,
I am trying to convert the KML file to shape file format using the generate workspace option and getting error . Also i am not sure how i can extract specif information from the KML .
I am attaching the KML file here . from this KML i want to extract the folder name which is nothing but the feature id and route 1 and 2 geometry with there descriptions. can somebody suggest how i can do this ?
davtorgh
Forum|alt.badge.img+12
  • Aug 20, 2020 11:12 AM UTC
Hi @gis2020​ ,
you need to expose the attribute 'kml_name'. See the attached workspace to extract the fatures 'Route1' and 'Route2' by filtering 'kml_name'. I can't understand what you mean by 'folder name'.
Hope that helps!
danilo_fme
Forum|alt.badge.img+58
  • Aug 20, 2020 11:20 AM UTC
Hi @gis2020​
If you want to extract the informations from KML kml_description ( like POS, DL, NEG, etc. ) you can use the transformer HTMLToXHTMLConverter.
Thanks in Advance,
Danilo
gis2020
  • Aug 20, 2020 12:37 PM UTC
Hi @gis2020​
Thanks in Advance,
Danilo
Hi @danilo_fme​  Thank for the suggestion. each KML has number of id's and for each id there is route 1 and route 2 i want that id name also for each route along with geometry and pos,neg,DL . i am attaching the screenshot of this.
gis2020
  • Aug 20, 2020 2:13 PM UTC
Hi @gis2020​ ,
Hope that helps!
Hi @davtorgh​ ​ Thank for the suggestion. each KML has number of id's and for each id there is route 1 and route 2 i want that id also for each route along with geometry and pos,neg,DL . i am attaching the screenshot of this.
