JSON Query Predicates
  • Feb 9, 2021 5:29 PM UTC
  • 147 views
dbaldacchino1
Forum|alt.badge.img+14
I think I know the answer is "can't do this in FME yet", but thought of asking anyway :) Is there a syntax for constructing a predicate in JSON Query when used in a JSONExtractor or JSONFragmenter transformer? Basically I'm after getting to the data within complex JSON structures quicker and avoid having to fragment/flatten everything and then filter afterwards. Attached is an example: with a predicate, one would be able to get to the proper "Food" object in the array based on the predicate "Type"="Fruit", instead of having to flatten the whole thing, testing and filtering, then exploding again. Assuming this is not really possible, I also wrote a broader post in the Ideas section. Thanks.
hkingsbury
Forum|alt.badge.img+73
  • Feb 9, 2021 6:48 PM UTC
That would be helpful to have, but from that documentation it appears that it is a function of a "[JSONata is a lightweight] query and transformation language for JSON data"
So safe would either have to build their own tools/functions/transformers to achieve similar results or license/include that language.
Regardless, have a thumbs up on your idea 👍
dbaldacchino1
  • Feb 9, 2021 7:51 PM UTC
Thanks, you're absolutely right. I thought there was some kind of standard way to do JSON querying. Maybe I should have made reference to JSONPath perhaps...there seems to be definite room for improvement here, especially if you are using FME heavily to interact with web services.
