Is there a way to keep duplicate stacked points but offset only the duplicates' z-value by value of 1?
  • Nov 30, 2022 3:19 PM UTC
  • 116 views
casheddy
I have migrated data into Utility Network but have a large amount of duplicate stacked point features. They all need to remain but the network topology will remain dirty unless I find a way to make these duplicate XY's unique. After testing a few manually, it seems to work if I add a z value of 1 to only the duplicate points and revalidate topology. So if I could add a z-value of 1 to only the duplicates using FME, it would solve my issue. Any help is greatly appreciated!
dustin
Forum|alt.badge.img+36
  • Nov 30, 2022 3:29 PM UTC
You can find the points with duplicate geometry using a Matcher, give each duplicate within the matched groups a unique id via the Counter with Group Processing set to _match_id, then offset the z via the Offsetter with the Z Offset set to _count
casheddy
  • Nov 30, 2022 3:32 PM UTC
Thank you! @dustin​  I will use this workflow and follow up to let you know how it works. Greatly appreciated!
casheddy
  • Dec 3, 2022 12:57 AM UTC
This worked perfectly. @dustin​ - Thanks!
