Is there a way to copy to excel user attributes table of any writer?
  • May 17, 2023 2:28 PM UTC
  • 6 replies
  • 79 views
esalmagul
Is there a way to copy to excel user attributes table?
I need to reproduce the table of writer attribute names, data type, width, value, precision. Figured there must be a way to extract those fast?
Capture
caracadrian
Forum|alt.badge.img+23
  • May 17, 2023 6:23 PM UTC
I recommend saving the writer in an empty workspace and using the FME Workspace Reader on it.
You will find the the parameters you need under FeatureTypeUserAttributes. Just process the strings to get the needed values.
Excel FMW ReaderThis is what I get for the setting on the right.
esalmagul
  • May 17, 2023 6:47 PM UTC
Can I just copy and paste this? I need to extract all data type and lengths.
When I try to do so, I end just pasting that one value
caracadrian
  • May 18, 2023 10:32 AM UTC
Sorry, no copy/pasting. Some transformers have an import function but I haven't seen an export one.
Forum|alt.badge.img+54
  • May 18, 2023 1:06 PM UTC
You can copy and paste the results from the FeatureTypeUserAttributes
Process user_attribute_type to get type and width separate, keep the attributes you want
imageThen select all by clicking top left in the inspector, and right click to copy with headers and then you can paste where you need it
esalmagul
  • May 18, 2023 2:31 PM UTC
Would you be able to share the steps?
Thanks!
fpaquet
Participant
  • Participant
  • May 30, 2023 7:22 PM UTC
I have the same issue. I want to get the user attributes in an Excel table, but I just can't figure out how. Did you finaly got it ?
Thanks
Frédérique P.
