Is it possible to use pre-write SQL to delete features in a file geodatabase feature class?
  • December 15, 2020
  • 49 views
aguan
Forum|alt.badge.img+11
I see the file geodatabase writer has pre and post writer SQL options. So I assume I can do some deletion before inserting. Can I do "delete from table where attribute = 'attributeValue'"? Not sure what the syntax should be.
Best answer by hkingsbury
A better approach would be to use a FeatureWriter to delete these features before they get written. You can add a WHERE Clause to filter out those you want to removeScreenshot 2020-12-16 080725
hkingsbury
Forum|alt.badge.img+56
  • December 15, 2020
  • December 16, 2020
The problem is that the pre and post SQL does not have any notion of feature attributes, so you cannot reference any feature attributes in the SQL. However, you can reference private or public parameters.
If you need to delete based on a feature attribute, there is the DatabaseDeleter transformer, or you can look into the suggestion from @hkingsbury​
aguan
  • December 17, 2020
@hkingsbury and @david_r, thanks for the advice. I will try use where clause. Basically delete existing records before inserting new ones. Use this for RDBM like Oracle all the time, never used against a file geodatabase.
