Is it possible to calculate the average distance between two lines ?
  • Feb 10, 2022 3:44 PM UTC
  • 679 views
katt
Forum|alt.badge.img+12
I have a dataset of two lines and I want to calculate the average distance between them. I can use the NeighborFinder to get the closest distance between these two lines. (As you can see on the image the closest distance could only be an outlier.)
But I want to know how far they are from each other in average as these two lines are almost parallel. Is this possible to calculate ?
danilo_fme
Forum|alt.badge.img+58
  • Feb 10, 2022 4:56 PM UTC
Hi @katt​
Have you tried to extract the points ( begin and end ) of the lines first?
Thanks in Advance,
Danilo
katt
  • Feb 10, 2022 6:31 PM UTC
Hi @katt​
Thanks in Advance,
Danilo
Hey danilo_fme, I am not sure why to do so? Also the following scenario is possible. The outlier is not necessarily at the end/beginning of the line.image
hkingsbury
Forum|alt.badge.img+73
  • Feb 10, 2022 8:08 PM UTC
Heres one approach, Assume you name one line 'A' and one line 'B'
imageOn line A use the iterative snipper and split into X number of lines. then extract the first coordinate and use those as the origins in the Rotator. Rotate the line 90 degrees. These lines (we'll them 'C') are now perpendicular to line A.
imageNow extend C a suitable distance to be sure they intersect both lines A and B.
Then using an intersector 'cut' C into three parts, then use a spatial filter to find the C segments that fall between A and B
imagenow calculate the length of the cut C segments and use a StatisticsCalculator to get the average length of all the C lines.
Have a look at the attached workbench :)
  • Feb 11, 2022 2:59 AM UTC
Hi @katt​ , here is another approach. ​The basic concept is:
average distance = area between the two lines / longer axis length of the area
The attached workspace is an implementation example.
