insert a decimal in a number string
  • September 22, 2022
  • 6 replies
  • 172 views
dos_gis
Forum|alt.badge.img+3
Hi, I'm trying to insert a decimal into a string of numbers, so 123456 becomes 1234.56
Thanks!
Best answer by carmijo
dos_gis wrote:
Almost but my number string isn't always the same length. I'm looking to add a decimal in front of the last two numbers regardless of the string length.
This should work for you. image.png--
If i've provided something helpful, please upvote the comment. If i've provided a solution, please mark it as 'Best Answer'. This marks the post as answered and helps the community find the solution. If I didn't provide a solution, please let me know if I can help further. Thanks! 🙂
carmijo
Forum|alt.badge.img+11
Hey there @dos_gis​, You can do this a few different ways. You could use regex inside the stringreplacer transformer like mentioned here -
http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/stringreplacer.htm
or the stringinserter custom transformer
https://hub.safe.com/publishers/safe-lab/transformers/stringinserter
Here's a super helpful resource I use when working with regex - https://regex101.com/
dos_gis
Thanks. I've been trying the stringreplacer with regex:
[0-9]{2}+$
Replacement Text: .\\2
It's not adding the decimal just replacing the text
carmijo
[0-9]{2}+$
Try this out - image
dos_gis
carmijo
  • September 23, 2022
dos_gis
Thank you. This did the trick.
(\\d.{1})$
Replacement text: .\\1
