I would like to extract the string name of path in attribute
  • February 5, 2023
  • 48 views
spiderman
Forum|alt.badge.img+7
Hi ,
i have path file name in attribute
C:\\*\\*\\*\\filename.dwg
i would like to extract only the (filename.dwg)
 Please , I want to remove C:\\*\\*\\*\\
Thanks in advance
Best answer by danilo_fme
Hello @spiderman​
I suggest you to use the transformer FilenamePartExtractor.
Path
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+45
  • February 5, 2023
Hello @spiderman​
Path
Thanks,
Danilo
