I use SQL creator to import a view from SQL server. It represents lines but comes in as multipoint geometry. The linebuilder to create lines from multipoints doesn't work. Any ideas instead of de-aggregating to individual points?
  • Jul 31, 2020 5:18 PM UTC
  • 12 replies
  • 113 views
lennertpronk
Have you tried a GeometryCoercer? Not quite sure what it will do in your case without a sample set of data.
lennertpronk
  • Jul 31, 2020 7:27 PM UTC
Hi, I just tried it but has no effect. The input has geometry aggregate. I applied aggregate filter and a a geometry refiner and wrote to File Geodatabase as a multipoint. Although from there to lines I have no clue. A multipoint to line would seem logical in FME, but I couldn't find it?. thanks
Try using the Microsoft SQL Server Spatial reader. That should pull in the geometry properly.
  • Aug 2, 2020 12:35 AM UTC
Hi @lennertpronk​ , Deaggregator and LineBuilder would be a solution, but if you don't want to do that, a PythonCaller with this script might help you. Assuming that input geometry is always a MultiPoint.
import fmeobjects
def replaceMultiPointWithLine(feature):
    coords = [p.getXYZ() for p in feature.getGeometry()]
    feature.setGeometry(fmeobjects.FMELine(coords))
lennertpronk
  • Aug 3, 2020 12:18 PM UTC
Hi @Takashi Iijima​
Thanks, Although get this error
FFS writer: Writing 1 feature(s) to file 'C:\\Users\\LOCAL_~1\\Temp\\wb-cache-FME_OSP_UA-kvoQQG\\Main_SQLCreator_11 -1 98 fo 0 RESULT 0 e0a5d9da31d17caaa4198afb8bc1d1604953e978.fts'PythonCaller (PythonFactory): Splitting bulk mode features into features
PythonFactory failed to load python symbol `FeatureProcessor'
Factory proxy not initialized
PythonCaller (PythonFactory): PythonFactory failed to process feature
Microsoft SQL Server Spatial Reader: Closing `AFRW_WHX_REG_WGS84' . Read operation complete
Stored 1 feature(s) to FME feature store file `C:\\Users\\LOCAL_~1\\Temp\\wb-cache-FME_OSP_UA-kvoQQG\\Main_SQLCreator_11 -1 98 fo 0 RESULT 0 e0a5d9da31d17caaa4198afb8bc1d1604953e978.ffsupdating'
Saving spatial index into file 'C:\\Users\\LOCAL_~1\\Temp\\wb-cache-FME_OSP_UA-kvoQQG\\Main_SQLCreator_11 -1 98 fo 0 RESULT 0 e0a5d9da31d17caaa4198afb8bc1d1604953e978.fsi'
Finished saving spatial index into file 'C:\\Users\\LOCAL_~1\\Temp\\wb-cache-FME_OSP_UA-kvoQQG\\Main_SQLCreator_11 -1 98 fo 0 RESULT 0 e0a5d9da31d17caaa4198afb8bc1d1604953e978.fsi'
Translation FAILED with 5 error(s) and 0 warning(s) (0 feature(s) output)
FME Session Duration: 2.3 seconds. (CPU: 0.5s user, 0.6s system)
END - ProcessID: 20620, peak process memory usage: 166184 kB, current process memory usage: 125980 kB
Program Terminating
Translation FAILED.
itsmatt
Forum|alt.badge.img+48
  • Aug 3, 2020 12:24 PM UTC
What is your SQL in the SQL Creator?
I agree with @jlbaker2779​ that the Microsoft SQL Server Spatial reader should do the trick here. You mention that you are creating a view though so that could add a bit of a challenge. There is a parameter called SQL to run before read which might help
lennertpronk
  • Aug 3, 2020 3:08 PM UTC
select * from dbo.[DovSeismicLine2DGeometry]
lennertpronk
  • Aug 3, 2020 3:35 PM UTC
A little sample straight out of sql server spatial
itsmatt
  • Aug 4, 2020 7:18 AM UTC
ok so in this case your points are ordered so you can just use a deaggregator to get the individual points and then use a LineBuilder where you group by Line_ That gave me 9 nice looking lines
lennertpronk
  • Aug 4, 2020 11:42 AM UTC
@virtualcitymatt​
HI thanks. Although i have 100 Thousand lines and 20 Million points. There much be a quicker why to do it.
Essentially my multi-points are already lines , sorted etc... So wonder if there is some geometry replacer to have it run more economically instead of deaggregating and aggregating again.
  • Aug 4, 2020 1:22 PM UTC
Hi @Takashi Iijima​
Program Terminating
Translation FAILED.
You have to set the function name "replaceMultiPointWithLine" to the Class or Function to Process Features parameter in the PythonCaller.
lennertpronk
  • Aug 6, 2020 5:12 PM UTC
Thanks that solved it. I had to de-aggregate after all as get(XYZ) only works on Points 😀
