i need to find number of time same value in particular list
  • Feb 2, 2023 10:50 AM UTC
  • 5 replies
  • 64 views
dustin
Forum|alt.badge.img+36
  • Feb 2, 2023 11:04 AM UTC
If it's in list format, you can use the ListHistogrammer. If this is simply attributes on features, you can use the StatisticsCalculator with Group Processing set to path_filename. The parameter you want to output is the total_count statistic. From the Summary port, you would receive one feature for each unique value with a total count attribute appended.
danilo_fme
Forum|alt.badge.img+58
Hi @malikusama95​
I suggest you to use the transformer StatisticsCalculator:
Sta
Thanks in Advance,
Danilo
malikusama95
Hi @malikusama95​
Sta
Thanks in Advance,
Danilo
i want count of same value
malikusama95
Hi @malikusama95​
Sta
Thanks in Advance,
Danilo
thanks
rahulsharma
Forum|alt.badge.img+12
There are a few different ways to achieve this using StatisticsCalcular or Adjacent Features in AttributeManager
Count Same Values in List
