I have done a string concatenator on a series of attributes with numbers, however, I cannot tell the sequence of numbers apart as they are now all merged, is there any way to add commas or spaces in between the values during string concatenator proce
  • Mar 22, 2021 11:33 AM UTC
  • 349 views
Screenshot 2021-03-22 at 11.32.52
Best answer by caracadrian
Hi, thanks for that!
I've looked at using the attribute manager/creator to put a separator between the attributes but have only been using FME for a few weeks, could you provide more guidance on how I would do that?
Also any advice on how I could have avoided that using ListConcatenator would be appreciated.
Thanks
StringConcatenator settings:
StringConcatenatorAttributeCreator/Manager settings:
AttributeCreatorListConcatenator is used when your incoming data is in list form. You can read this tutorial: Tutorial: Working with List Attributes (safe.com)
Forum|alt.badge.img+63
Not automatically, but if you set up the string concatenation you can add those in yourself.
caracadrian
Forum|alt.badge.img+23
  • Mar 22, 2021 12:19 PM UTC
If you used the StringConcatenator you can add Constant String Type Parts.
If you used AttributeManager/Creator just put a separator between the attributes.
If you used ListConcatenator we wouldn't have had this discussion.😁
Thanks
caracadrian
  • Mar 23, 2021 11:21 AM UTC
Thanks
