I have a column that contains a lot of special characters. By using transformer 'StringReplacer', I can replace i.e. an '#' by an ' '; How can I replace a list of special characters of 10 or more characters. Do I need to use 10 StringReplacers?
  • Nov 29, 2023 1:47 PM UTC
  • 5 replies
  • 279 views
Best answer by itsmatt
Another optoin is to use a reular expression - this one should work:
The "|" charachter in a reqular expression is like a logical OR. You need to use "\" to escape some of the charachters.
dustin
Forum|alt.badge.img+36
  • Nov 29, 2023 1:55 PM UTC
How is the column with the special characters structured? Space delimited? Comma delimited?
  • Nov 29, 2023 2:02 PM UTC
I read the column from a database. All characters used are readable. Every record in this column is varchar(100). I need to change most of the special characters by ' '; my special character list that need to be replaced are: !"§$%/()=?\\*+'# but not &-
  • Nov 29, 2023 2:14 PM UTC
Did you look at the StringPairReplacer? Note that you must use <backslash>+<space> to indicate that you want to replace something with a <space>, as explained in the documentation. Example to replace # and ! with a space:
itsmatt
Forum|alt.badge.img+48
  • Nov 29, 2023 2:25 PM UTC
  • Nov 29, 2023 3:00 PM UTC
Excellent!
