HTML Report, ESRI Leaflet, feature layer info
  • October 19, 2023
  • 132 views
tdun
Forum|alt.badge.img+3
Hi all,
I am generating a HTML report that includes a Map (ESRI Leaflet).
This all works fine, but was wondering if it's possible to click on the map and get information from the Feature Layers on my map?
If i click on the objects on the map I get no details. I was hoping for the underlying metadata to pop up ?? Is this possible?
thanks
j.botterill
Forum|alt.badge.img+48
  • October 20, 2023
heya tdun, I think you probably want to create an attribute e.g. alabel and in the text editor build all the html syntax passing in other attribute values. html_in_text_editor_new_attribute_value Then in the htmlreportgenerator, you set the "Label Attribute" as the new attribute that has the html syntaxhtmlreportgenerator_alabel_attributeVote up any HTML or leaflet idea in the fme community
AC Idea: HTML Annotations (safe.com)
AC Idea: HTMLReportGenerator Table Styling (safe.com)
AC Idea: HTMLReportGenerator Update (safe.com)
