How to visualize PostGIS table with two different geometry types - Point & Polygon?
  • Sep 27, 2023 2:46 PM UTC
  • 262 views
marsh007
Forum|alt.badge.img+11
I've PostGIS table with two geometry types - Point & Polygon. When I read table, I'm only able to see Polygons. But point geometry column is only shown in table and unable to visualize.
Is there any way to visualize point geometry instead? How do we explicitly mention for which geometry columns to be visualized?
Thanks!
Best answer by chrisatsafe
Hi @fmeuser_gc​ ,
Check out the Reading Mulitple PostGIS Geometries section of this article. Essentially you just need to use a SELECT statement in the Reader Feature Type as FME will read the first geometry column by default and ignore the others. You can override it by using a SELECT statement. From there, you can expose the attribute and use a GeometryReplacer to visualize the geometry.
chrisatsafe
  • Sep 28, 2023 6:59 PM UTC
Hi @fmeuser_gc​ ,
marsh007
  • Oct 17, 2023 2:51 PM UTC
Able to visualize now. Thank You @chrisatsafe​
