How to use the "import" function to define attributes?
  • Nov 18, 2022 3:33 AM UTC
  • 153 views
Hi everyone,
I am trying to create a set of new attributes with the Attribute Creator. I would like to use the "import" option to bring the attributes from a CSV file. However, the transformer reads the attribute values as a "text" and not as Arimethic function (See picture for clarification ). Any idea on how to change that quickly?
Or any better idea to obtain the same result?
I mean create the following attributes:
Name Attribute
Y1 =A1+B1
Y2 =A2+B2
Y3 =A3+B3
Thanks in advance!.
question FME
Best answer by nielsgerrits
You can use the function @Evaluate() to do this.
Create a CSV like
Name,Value
A,@Evaluate(1+1)
Click Import...
Select CSV
Choose import from Attribute values
Select Name for New Arribute and Value for Attribute Value.
nielsgerrits
Forum|alt.badge.img+67
  • Nov 18, 2022 5:48 AM UTC
Create a CSV like
Name,Value
A,@Evaluate(1+1)
Click Import...
Select CSV
Create a CSV like
Name,Value
A,@Evaluate(1+1)
Click Import...
Select CSV
Thank you. It's working now.
