How to truncate a table while the writer is empty.
fme_hans
Forum|alt.badge.img+5
I have a workspace that truncates an SDE geometry table and refills it. The workspace runs daily and sometimes there are no records to write. In that case the writer only has to truncate the table. I don't see an option truncate first or anything like that in a sde writer.
How can I truncate a table while the writer is empty?
Forum|alt.badge.img+38
  • March 31, 2021
For this sort of scenario, I'd truncate the tables using an sqlexecutor upstream of the writers to ensure all tables are truncated.
fme_hans
  • April 1, 2021
Thanks. Now I use a creator followed by a sqlexecuter. This works.
  • March 15, 2022
In my case I'd like to truncate the table (FGDB feature class) that is in the Reader, after the table has been read. Is that possible?
fme_hans
  • March 28, 2022
I do not know. i never truncated right after the reader. I have to test it.
geomancer
Forum|alt.badge.img+48
  • March 28, 2022
An SQLExecutor downstream of the Reader should do the trick.
Note that one SQL query is issued for each feature that enters the transformer. So do make sure only one feature enters the SQLExecutor!
Maybe use a Sampler (sample the last feature!), or the combination of a Creator and a FeatureReader.
Trigger_SQLExecutor
fme_hans
  • March 29, 2022
Thanks, i will try this.
