How to replace spaces with commas?
  • Mar 26, 2021 12:08 PM UTC
  • 6 replies
  • 451 views
I have tried using string replacer to remove the blank spaces with commas but it doesn't seem to work? Screenshot 2021-03-26 at 11.58.54
I am hoping to get this attribute looking like the below? Any help on how to get here is appreciated.Screenshot 2021-03-25 at 09.51.35
Best answer by inge
If you use an AttributeSplitter with the comma as a delimiter character, it should work. This Transformer would allow you to drop empty parts. That would eliminate the multiple comma issue.
FYI, he AttributeSplitter has a list as output. Hope this helps!
Forum|alt.badge.img+63
How do you have your StringReplacer set up? Can you post a screenshot of the parameters?
In the text to replace window I did: (*space*)- will this work?Screenshot 2021-03-26 at 12.14.46
No, that will look for the combination ( ), which doesn't occur in your text. Simply putting just a space there should do the trick.
Great that worked but now i seem to have some with multiple commas? Screenshot 2021-03-26 at 12.19.21
is there a transformer that is best to use to now get those values into separate columns?
inge
Forum|alt.badge.img+3
  • Mar 26, 2021 12:29 PM UTC
