How to read each row of a column with pythonCaller?
  • Aug 17, 2023 1:02 PM UTC
  • 6 replies
  • 205 views
I am trying to access each row of the excel data I read with pythoncaller. How can I do that
        coulumnData = feature.getAttribute('Column1')
        data = str(coulumnData).split()
        for row in data:
            print(row)
and how do I read FLOAT values as well?
I do not understand what kind of object is returned by feature.getAttribute. If I print coulumnData, it is printed nicely row by row. But, how do I access those row of data? I want to do something like
        print(data[10])
Best answer by david_r
When I try to do this:
        for row in coulumnData:
            print(row)
I get this error:
The PythonCaller is called once for each row in your Excel, meaning you cannot access all rows by the column name. You'll have to add them up yourself, e.g.
import fme
import fmeobjects
class FeatureProcessor(object):
    def __init__(self):
        """Base constructor for class members."""
        self.column1_values = list()
    def input(self, feature):
        """This method is called for each FME Feature entering the
        PythonCaller. If knowledge of all input Features is not required for
        processing, then the processed Feature can be emitted from this method
        through self.pyoutput(). Otherwise, the input FME Feature should be
        cached to a list class member and processed in process_group() when
        'Group by' attributes(s) are specified, or the close() method.
        :param fmeobjects.FMEFeature feature: FME Feature entering the
            transformer.
        value = feature.getAttribute('column1')
        if value is not None:
            self.column1_values.append(value)
        self.pyoutput(feature)
    def close(self):
        """This method is called once all the FME Features have been processed
        from input().
        # Do some aggregate processing here...
        print(self.column1_values)
  • Aug 17, 2023 1:19 PM UTC
You may want to take a look at the documentation for feature.getAttribute():
https://docs.safe.com/fme/html/fmepython/api/fmeobjects/_feature/fmeobjects.FMEFeature.getAttribute.html#fmeobjects.FMEFeature.getAttribute
To iterate over all the attributes in a Python block, do something like:
for attr_name in feature.getAllAttributeNames():
    attr_value = feature.getAttribute(attr_name)
    print('{} has value {}'.format(attr_name, attr_value))
  • Aug 17, 2023 1:39 PM UTC
I did that as well (from another post). But, when I
I get this.
Now, I want to access each row as some sort of list. But, attr_value is some kind of FME object. How do I convert it to a list so that I can access each element one by one. I want to do something like
attr_value[0] = 'Apple'
attr_value[1] = 'Orange'
attr_value[2] = 'Banana'
But, right I only have this:
print(attr_value)
Apple
Orange
Banana
I want to access each element of attr_value. How do I do that?
  • Aug 17, 2023 1:47 PM UTC
            print(row)
I get this error:
  • Aug 17, 2023 2:02 PM UTC
            print(row)
I get this error:
import fme
import fmeobjects
    def __init__(self):
            transformer.
    def close(self):
        from input().
  • Aug 17, 2023 3:07 PM UTC
"PythonCaller is called once for each row in your Excel".. now that statement answers all my confusion !! Thanks !
Final question @david_r. How do I expose the values outside of python?
  • Aug 17, 2023 3:32 PM UTC
You can either expose them in the lower part of the PythonCaller dialog, or using an AttributeExposer.
