How to map the values in 1 source to that in another manually
  • Feb 15, 2021 3:52 PM UTC
  • 5 replies
  • 119 views
I have 3 shapefiles and and 1 spreadsheet I need to import into 1 PostgreSQL/PostGIS table
ADM1_area (Shapefile) is linked to the spreadsheet via a name column however due to differences in spellings this may need manual intervention
How Do I bring up both the Shapefile name column and the spreadsheet name column and where necessary manually map the values across the two?
for instance
MyPlace = My Place (Or one source might have diacritics )
This is probably a manual process as REGEX would take to long
The preferred name spelling will then map to the name column in PG table and all other spelling concatenate to a list in alt_names column
The other 2 shapfiles are ADM2_area and ADM2_point
these form 1 database row that has both geometry and point_geometry columns and are linked to the ADM1_area row via ADM1_name column this needs to be the same name used before and may need intervention
When I created the PostGIS connection I could only see how to had 1 geometry column not two?
Thank You
Best answer by markatsafe
@geo_geek​  That's correct, only the string and unique ID's are output. You then have to join back to the appropriate feature using FeatureJoiner. In the example below:
imagestr1 is the Input1 string to be compared.
String_2_matched max is the best match for Input2. String_2_matched_2th / 3th are the 2nd & 3rd best matches.
ratio_max is the ratio for the best match, and then ratio_2th / 3th for the next to matches
id1 is the Input1 unique ID
id2 & id2_ratio_max are the unique ID's (same value) for the best match. id_2_ratio_2th / 3th are the unique IDs of the 2nd & 3rd matches.
So you can use id1 to join back to the Input1 features and id2 to join back to the best matched Input2 features.
I've attached a small example workspace (FME 2020).
@geo_geek​  Have a look at the FuzzyStringCompareFrom2Datasets custom transformer that is available on the FME HUB. That might make the join for you.
  • Feb 16, 2021 5:30 PM UTC
Thanx I'll look tomorrow
FYI:
I've been playing with StringPairReplacer today to replace accented characters that fixed 7 of the 15 fails
My sample has 48 records with 15 fails
Adding multiple filters to clean text in my mind is not a good option because every source is going to be different
it would be faster to be able to bring up the two sources in a combined table specify the joining columns and manually join the 15 fails
  • Feb 17, 2021 10:39 AM UTC
@Mark Stoakes​  I had a look at FuzzyStringCompareFrom2Datasets  after adding two counters to the inputs to form ID columns this transformer seemed to work
However I'm unclear how to use it has none of the other input attributes are carried through
Unless I'm missing something?
In order to move forward
One of the input is a spreadsheet I've found it faster to add a column to this and copy and paste the other source name column 90% of this was in the correct order
This works on a small datasets (All mine are) upscaling it might become an issue
Thanx for your help
  • Feb 18, 2021 4:59 PM UTC
  • Feb 19, 2021 12:47 PM UTC
Thank you for your help
