How to identify parts of polygons which thinner than 0.2 meter?
  • August 27, 2021
  • 198 views
bobo
Forum|alt.badge.img+3
I got over 380000 polygons of landcover data and I'd like to find out which of them have parts thinner than 0.2 meter and identify where these thin parts are located, so I can fix them.
I've tried bufferer, but there's no luck for me, please help me, thanks very much!
virtualcitymatt
Forum|alt.badge.img+47
The Snapper might work. I think you could try and use the Segment Snapping mode and set the tolerance to be 0.2m
It might not be the right approach but it is where I would start. You might need to use the Group By processing and use a unique ID for each polygon to make sure that polygons don't snap to each other.​
hkingsbury
Forum|alt.badge.img+67
  • August 29, 2021
i dont have a solution, but another tool to consider is the bufferer with a negative value
caracadrian
Forum|alt.badge.img+23
  • August 30, 2021
jdh
Forum|alt.badge.img+40
  • August 30, 2021
This is not a great solution, but you can:
Buffer by -0.1: sections less than 0.2 are removed
Deaggregator
Buffer by 0.101: expand to approximately the same as original (excepting narrow sections), overshooting just a little to avoid slivers in the next step.
Clip original data by buffered data : Outside port is the narrow sections.
